Hi Community! I am writing my first post here to ask for your feedback and ideas/advice.
I am looking to build a 7970X-based high-end linux workstation to serve as a number-crunching and data analysis machine (mostly physics-based particle simulations and ML/deep-learning models - 90% of the time) and also a virtualization-capable machine (mostly Windows/Adobe/Blender to create educational and scientific publication material - 10% of the time). Simulations require fast GPUs, and data analysis and visualization requires lots of RAM and fast NVMe storage.
The first thought is: building another machine for image manipulation that will only be active at most 15% of my time seems terribly wasteful in terms of space, time, and $$, given that I will already have a very powerful machine on my desk. So, I am considering adding a dedicated GPU and NVMe drive for virtualization.
The second thought is: I have a variety of use cases and want this workstation to be future proof, but without having to use noise-canceling headphones to be able to work next to it. So, I am choosing low-power “quadro” GPUs for particle simulations, and an “entry-level” RTX for virtualization, so they use less power and produce less noise and heat.
Final though: This should cot around ~$12K, which seems feasible per Micro Center prices.
This is the configuration I have in mind:
- Asus TRX50-SAGE Motherboard
- Threaripper 7970X (32 core)
- Silverstone SST-XE360-TR5 (for CPU AIO Cooling) or Noctua (NH-U14S TR5-SP6)
- v-color 512GB or 256GB RAM 4-module kit (depending on price)
- GPU 1 and 2: RTX 4000 Ada (for simulation and AI)
- GPU 3: RTX 4060 Ti (dedicated for virtualization and PCI passthrough)
- 1 * Crucial T705 1TB PCIe Gen5 x 4 NVMe (OS and user data)
- 1 * Crucial T700 4TB PCIe Gen5 x 4 NVMe (simulation and AI cache)
- 1 * Crucial P3 Plus 500GB PCIe Gen4 x 4 NVMe (for virtualization)
- M.2 PCIe adapter w/ 4 * 4TB NVMe (local data storage for data analysis)
- PSU: Corsair AX1600i 80 Plus Titanium
- Case options: Fractal North XL (if using CPU AIO) or Torrent (for air cooling)
PCIe Lanes considerations:
- This system has a total of (per Motherboard manual) 48 Gen 5 lanes (CPU only), 32 Gen 4 secondary CPU lanes, and 8 Gen 4 chipset lanes.
- I will have 10Gb and 2.5 Gb connections active in this machine (2 PCIe Gen 4 lanes for the 10Gb connection and 1 PCIe Gen 4 lane for the 2.5Gb LAN)
- The RTX 4060Ti is PCIe Gen4 x 8, and the 4000 Ada is PCIe Gen4 x 16.
- In this motherboard, two NVMe drives are PCIe Gen 5 x 4 connected directly to the CPU, and the third is PCIe Gen 4 x 4 connected to the chipset.
Physically, I would set it up on the board like this:
— PCIe Slots (ASUS TRX50-SAGE)
- PCIEC16(G5)_1 (x16 - PCIe 5.0) – RTX 4000 Ada (single slot)
--- -- empty slot
- PCIEC16(G5)_2 (x16 - PCIe 5.0) – RTX 4000 Ada (single slot)
--- -- empty slot
- PCIEC16(G5)_3 (x8 - PCIe 5.0) – Gigabyte NVIDIA GeForce RTX 4060 Ti Eagle (dual slot - PCIe 4.0 x8)
- PCIEC16(G4)_1 (x4 - PCIe 4.0) – (covered by RTX Dual Slot)
- PCIEC16(G4)_2 (x16 - PCIe 4.0) – M.2 adapter
And the PCIe usage would look like this (still trying to follow Motherboard manual):
CPU PCIe 5 - 16+16+4+4 (4000Ada “1” + 4000Ada “2” + 1TB NVMe + 4TB NVMe)
CPU PCIe 4 - 8+16+2+1 (RTX for Virtualization + M.2 adapter + 10G LAN + 2.5G LAN)
Chipset PCIe 4 - 4 (0.5TB NVMe drive)
Total CPU PCIe Lanes: 5=40 ; 4=27
Total Chipset PCIe Lanes: 4=4
Main questions:
- The two RTX 4000 Ada GPUs are PCIe Gen 4 x 16, so even though they are mounted on Gen 5 slots, they will downgrade the connection to Gen 4. Will this eat into the 32 Gen 4 CPU lane “budget”, or will the CPU downgrade the Gen 5 PCIe lanes into Gen 4 PCIe lanes? in other words, if I only connect one RTX to the PCIe Gen 5 slot (and no other card or NVMe), will I still have 32 PCIe Gen 4 (CPU) lanes available, 4 Gen 4 chipset lanes, and another 32 Gen 5 CPU lanes?
- CPU cooling should be quiet under load, this box will sit next to me on my office. Would the noctua and silverstone CPU cooling options be similar in noise level under load?
- I am thinking the North XL would be better for AIO (top mount) and Torrent better for air cooling. I worry that mounting the AIO by the front 180mm fans of the Torrent would bring in hot air for the whole system. Does that make sense?
- v-color RAM was in the list of compatible modules, but I never used v-color before. Any details to be mindful about here?
- The chosen PSU was based on HW Busters reviews, which indicated this has the lowest power fluctuation among similar choices. Power fluctuation seemed to be a big problem for others in this forum when using Threadripper systems. Seasonic Prime PX-1600 v3 was another option. Was there ever a conclusion to what would be a “maximum” power fluctuation level for a stable system?
- I read here that for PCI passthrough, a “non-quadro” GPU is necessary. Is that still the case? This is the main reason for having a 4060 in this configuration.
I am open to any feedback, from “none of this makes sense” to “sounds cool, send me a picture”. What do you think?
