I have been trying to work this out in my head for a bit and getting a headache trying to sort it. I need some help, so I figure this would be the best place to ask. I will do my best to describe the situation I need a solution for.
Displays- 3 x32 inch monitors (2x1080p +1 4k) + 1 65" 4k TV
-Gaming/video editing rig (being built right now)
R7 2700x, GTX 1070ti Windows 10
-Capture RIg
6600k 1050ti elgado hd 60 video capture dual boot Win10/Linux Mint
-Latop with single HDMI out
- Xbox1x1
Here is what I would like to be able to do.
Use each of the 2 towers in a 3 monitor set up at times
have the middle monitor be able to switch to any of the devices also the TV
capture from any machine on any screen with OBS
so computer 1 has 3 outputs
computer two has 3 outputs i capture input
computer 3 has 1 output
xbox has 1 output
What the heck do I need to make this all work without unplugging, replugging and messing around?
I want to be able to use all 3 on the two desktops or switch any of them to either or the laptop or the xbox and switch any screen to display on the big tv and be able to capture any screen to stream.
4 4x4 hdmi matrix switches?
It doesn’t seem like this would be too abnormal of a set up to have a 2 pc gaming/streaming system with 3 monitors and a tv with a console. The laptop is a bonus that I would like to also add into the mix because the screen is too small for my blind self.
