MSN is screwing with me!
Ok, so I just installed skype on my PC and MSN is now poping up when I open Chrome. It opens with my regular google tab and is kind of agervating. I've done everything I can think of and am out of ideas. So if one of you tek geniuses could help me out it would be much appericiated. Thanks in advance.
(P.S I use Windows 7 don't know if that matters)
skype and msn are one of the same thing now
So there's no way to remove MSN from my tabs (aside from manually everytime time). I mean its no biggy if i can't, but just curious.
Go to your settings and where it says "On startup" the third bubble should be checked, It says "Open a specific page or set of pages. Set pages" you will want to click the set pages button.
In that menu you will probably see google and msn, if so hover over msn then click the X that is to the right of the URL on the end of the selection and press OK.
I didn't notice that option, thanks man.
