I have my Hackintosh up and running but cannot get the Ethernet working. I don't not have a WiFi option so I need to get this running. This is my first attempt at a Hackintosh so I pretty much have no idea what im doing. I used this post as a guide, just so you know what I have done.
http://www.reddit.com/r/hackintosh/comments/1nqi1x/successful_mavericks_installation_instructions/
Any help would be awesome.
Run Multibeast again and go to the Drivers tab, select Network from the left side and then select an option where it should say "Intel", it should be the 2nd option. After that, select the Build tab and finally, install it. Reboot the machine and see what happens.
I fixed it but thanks. I had tried running Multibeast a few times and even formatted and reinstalled OS X Mavericks and nothing worked. I ended up finding someone who had the same issue who supplied me with debugged kexts which I had to install manually and all is running fine. Actually using it now to type this up.
