Hi, I’ve updated my bios to latest version on MSI x470 gaming pro M/B, gui has change to text based and i have lost option to enable SVM in advanced mode. It does say SVM yes in bios, but is switch off in windows. anyone now how to switch on thks… CPU AMD Ryzen 5 2600. In Task manager ,virtualisation disabled: Disabled, Hyper-V-Support: Yes.
P.S. everything online relates to old bios GUI…
The easiest way, might be to reinstall windows. As much as that can suck. Also might not work and be a waste of time.
Maybe 1st check through every option that is related to virtualization and make sure it’s all on.
I would try to re-flash the bios again.
tryed that, no option to turn on svm in new bios…
tryed that
This thread helpful
