MSI GTX970 artifacts
Hi peeps,
so...yesterday my MSI GTX 970 started to suddenly show artifacts and the video card driver crashed due to TDR timeouts. I restarted the PC and it seemed fine again until i physically moved the GPU a bit. It sags quite a bit and i wanted to check if lifting the card changes anything and indeed it did....it got worse while doing so.
This seems to translate to a broken solder joint or something like that, since it comes up as soon as I physically lift the GPU.
Now my question...Is there a possibility that reflow soldering the card will fix this? I'm not a newbie in reflow soldering as I work in electronic manufacturing and actually have an oven where I can set a custom temperature curve.
Does anyone have any experience in that topic (what temps are needed etc)?
there are a few vids on it i know linus did one and i think the tek team did one at one point.
If you ever get it fixed either dyi, or RMA. Get this to prevent sagging again.
Puget Systems Universal Acrylic GPU Brace
