MSI GTX 660Ti PE Overclocking
Hey Everyone,
I was just looking at Linus' results for overclocking his 660 Ti PE, I know that no two graphics cards are the same but I am getting NOWHERE near his results, I'm talking FC3 crashes with a 20MHz OC. I'm using MSI afterburner to OC. Any suggestions?
My System:
 AMD Phenom II X6 1090T OC at 4.0 Ghz
ASROCK 990FX Extreme 9 Motherboard
16 GB Kingston HyperX Black Edition 1600mhz memory
MSI GTX 660TI PE OC
120 GB OCZ Vertex 3 SSD
2 TB Western Digital Caviar Green HDD
Corsair TX750 Power Supply
OS: Windows 8 PRO
Thanks for the help!
Make sure you have the latest drivers and the latest version of afterburner.  Make sure your cpu is rock soild stable like 24hour prime test or somthing becuase that can casue crashes and low fps.  Also in cpu bound games the 3960x linus uses is much more powerful then your 1090t so you would in turn get lower fps.  Other then that idk about the 660ti I don't have one my self but when my freind got his hd7770 he had the same problem on the early drivers.
sweet, we have some of the same stuff. list what driver you are using. i have over clocked my 660 Ti PE a little bit, and i am seeing 20FPS gains. i am using Afterburner version 2.2.3, it allows for some more overclocking than the other versions. hope my settings help.
core voltage @ +100,core clock @ +115,Memory @ +572,Fan speed @ auto
My set up
i5 3570k
Msi - z77 board
msi - 660 ti pe
Kingston hyper x 16 GB 1600MHZ
Thermaltake 850w
Crucial SSD 128 GB
WD 1 TB
I am using the latest NVidia Beta Driver, but I will be reformatting soon, 314.14
