Msi carbon pro x370 bios custom fans curves
what best custom fan curves from motherboard 5 140 fans in bios for carbon pro msi x370 any good recommendation pictures or video i dont like my computer turns almost full power fans to full speed and software is glitch and i want them run quietly and raise up when there mostly need it and when i watch videos or do homework as Microsoft i dont need fans going full speed and can i use the same one of the gpu custom fans curve too?
I will try and answer as best i can but i run my case fans at 50% from bios and then through MSI application when i run my overclock i have them custom tuned for what works for me. I have noticed that it is a “smart” fan setup so it will actually ramp the fans higher than what you set them at depending on conditions i have not figured out yet. So just mess with it til you find something you can deal with.
so smart fan is glitch i turn smart fan on everything and custom fan curves
Depends on what kind of noise you’re able to tolerate, how loud your fans are, what are your cooling needs and so on. If you want to make a good fan curve you need to check the thermals and noise level you want to achieve. When you’ve figured out what’s the best combination of both for you go ahead and make a profile
i use 6 noctua fans d15 with two fans 140 and i do not overclock but i do game and stream and maybe use adobe autodesk i want silent to move slow up so do i get corsair switch
https://www.amazon.com/Corsair-Fan-Controller-Commander-CL-9011110-WW/dp/B0725HP1J2/ref=pd_ybh_a_9?_encoding=UTF8&psc=1&refRID=P3DN5AV98HG60XG8S241
Did you download msi software yet?
i did i didnt work that ,ch it will reduce it but i try to do everything Manuel 50% as it lowers and pump as i may put the cpu fan there and the weird if i use to much the software it gives me blue screen error reboots back normal and each custom fan and Manuel dont safe automatic so each time i need to make it as that pain
