My B350’s always taken a while to start up, however after my PC went into sleep mode after being alone I was unable to wake it. I restarted the PC and it wouldn’t post. It turns on and all fans spin, but the troubleshooting LED remains on and the PC never posts.
I have since :
Flushed the power
Disconnected and reconnected the PSU
Unplugged everything from the PC
Plugged a keyboard back in, and a monitor.
Re-seated the CPU
Re-seated the RAM
Re-seated my GPU
Re-seated CMOS battery
Shorted the CMOS pins
Disconnected all of my fans and rebooted
I have absolutely no money and work to do so I’m a little panicked here. Does anybody have any suggestions or extra troubleshooting steps to take?
maybe the bios-chip went bad. is it removable?
You could / should, try a bios Flash if possible.
If the chip went fully bad, the board should behave the same without the chip.
It is unlikely, but it happened on two of my rather old Rampage iv Formulas, so yea.
I think this is my next course of action. I’m currently deadass just rebuilding the PC on cardboard and if I seriously 100% cannot get it to post I’m just gonna have to be without for a while
Got a funky laptop setup going on now though. That’s exciting.
It’s a CHUWI Lapbook, it’s a lovely little machine for getting basic work done on the go and watching shows. It’s really not cut out for the work I want it to do, but it could definitely be worse. This is home base for the time being
Also yeah in the process of doing so. Tried earlier with no luck but it can’t hurt…
