I bought this mobo a while back(Oct.)(10/2/12) and the new veshria chips came out after I bought the mobo, so I bought the amd FX-6300 to go with it.*This is my first build* I am waiting for the gpu to arrive then I will build it, but I heard you need to update the bios how can I possibly do that?I am very confused now. Will the computer post and go to the bios or what will happen what is the worst and least case that can happen after I install this cpu
Thank you! What will happen if I put the cpu in? will it not post?
update the BIOS, pretty sure if it will work with bulldozer it will owrk with piledriver
