I am wondering what should i get
MSI HD 7870 Twin Frozr III 2gb
or
Sapphire R9 270 2gb
The r9 270 is 10% more expensive so keep that in mind
Or if you have anything better that this for the same or similar price tell me
or
Sapphire R9 270 2gb
Topic moved to gpu section!
The 270 and 7870, are basicly the same card, so it does not matter in terms of performance. if you go a 7870 or 270.
You can find a 270 for cheaper if im right.
same counts for the 270X and 7870ghz.
There is not nothing better to get arround the 150-200 doller price range.
