MS Word problem- So embarassing
Ok so this is pretty embarrassing to have to ask for help with a simple application like Word but I'm stuck here. I recently got another cert and am trying to update my resume. When trying to insert the new cert into my resume I'm able to type the name in fine but when I get over to line up the cert date it drops me down another line. I'll attach some images so you can see what I mean. What am I missing here?
Change the header start line on the top by dragging the arrows maybe? Every time I use word I have to fuck around with it to get it to do what i want.
It may be the the tabs on lines with the properly aligned certs are different from those of the line "Certifications" above it. As you are adding above, perhaps if you start between the "C" and "o" of the CompTIA A+ line, single-backspace out the "C", enter your new cert with date, hit enter, and then finally add a new "C" for the former first line, it may work.
I honestly just messed around deleting and adding lines and somehow it worked.
