MP3 Quality
Continuing with our theme of high grade audio. I wanted to know what audiophiles think about MP3s. Almost all of mine are 320kbps which if I understand is the highest quality possible with an MP3? Please correct me if I'm wrong. Is this an acceptable file format for justifying the cost of $350+ for a nice DAC and headphones?
I can barely tell the difference between 256 and 320 with my consumer grade regular headphones. Thanks for the heads up.
Yeah, the difference is hardly tangible unless you know what you're listening for.  Wave lossless is dandy since it can be played by most media players, but I use flac when I upload to Google Music.
MP3 Files have the top and bottom frequencies that are close to human hearing threshold removed.  The result is a somewhat artificial and boxy sound but a much smaller file size.  If you go between Wave Lossless and MP3 versions of the same song, the wave file will feel freer and have better bass. The difference is slight, but it's certainly there. :)
You can go higher than 320kbps, but you are going outside the mp3 standard when you do that.
A program called dbPoweramp can produce mp3's at 640 kbps in Free Format mode. I have never tried it, but then again I cant see the use either. Also, any higher then 320 kbps and you will run into player compatibility issues apparently.
Personally I don't see any reason to switch from 320 kbps if its working for you. The only reason to switch to flac is if you intend to encode in a frequency higher then 48 khz or if you absolutely must preserve the original audio data. but then again if you need to preserve the audio perfectly, using raw wave files will do the same job but with less compatibility headaches.
Sounds good to me. I think I'll pick up a DAC and some headphones soon and see what I think and go from there with testing other formats. Thanks all.
My personal experience has been that mp3's totally leave the sound compressed. I'd explain how compression ruins sound to make it louder but that would be a huge post.
I have a really high end analog system (tube amp, turntable, and very good speakers) and I have a middle of the road 7.1 surround. To listen to a record, then flac, then mp3 back to back I personally can tell a difference. Records still sound the best but FLAC's are nearly as good. So much so I stopped buying every record I could and now only buy the very favorite music. Mp3's on the other hand suck in a critical listening.
I still have mp3's because they are mobile. I can load 25k songs and drive all day without repeating a song. In the truck I'll never be able to tell a difference.
What is more important than the file type is how well the music was mastered. Most music is put together pretty shittily, so the difference between mp3 and flac is not too noticeable. Look up stuff about the loudness war. It is pretty much insane. Anyway, get some mp3 and flac/wav versions of some music that you like and compare. You make the call yourself. Personally (with my ~$330 set up), I don't notice it too much when I am listening to an mp3 instead of a flac file. What I really notice is how well the song was put together in the studio. How well the artists did during the recording and things like that. Humans make mistakes a lot and they can be very noticeable with a decent set up.
Here is a golden nugget of wisdom. Vintage amps are a gift from god. You do not have to look far. I have a Marantz 2245 and it is amazing. And analog is plenty fine for you considering that your audio setup does not have a ton of emi noise. The high impermanence headphones are really best for studio because studios have all of those electronics that can cause noise..
Again, necro. Read the date.
