I have always been primarily a console gamer, I've dabbled a little bit in pc gaming in the past but not much at all really.
So currently looking to build my first pc and could use some advice. I am looking to use it as an all rounder really, gaming (I do love pretty graphics), a bit of 3d modelling and also using it as a media center.
I should mention that I already have the motherboard and case, as I got a great deal on these from a friend, everything else I'm open to suggestions.
CPU: AMD FX-8350 4.0GHz 8-Core Processor
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: Asus SABERTOOTH 990FX R2.0 ATX AM3+ - ALREADY OWN
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Asus Radeon HD 7950 3GB Video Card
Case: Corsair 600T White Graphite ATX Mid Tower Case - ALREADY OWN
Power Supply: Corsair Builder 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply
The overall PC build is great :) : You have the 8350 with one of the best if not the best 990FX mobo's (great OC capabilities) . With the h100i you can take your CPU to 4.8 - 5.0 GHz with not much effort . The Graphite 600T is an awesome looking case with great airflow and the PSU fits the system aswell altough in the future if you want to add another GPU i think you'll be safer with a 850W. The graphics card is good aswell . My only concern are the memories and the SSD : I think you should take a look into the Corsair Vengeance rams , they perform better and they have better cooling + they look awesome and for SSD you should go for the Kingston HyperX 3k 120GB or the A-DATA SX900 128GB.
PS : If you have the budged I think you should go ham and crossfire 7950 and get a PSU with more power :D
I haven't really read up much on running 2 cards, but I would love to do that in the future. Would I need any extra cooling if I were to do crossfire?
Also what are your opinions on the bronze, silver, gold etc ratings on the power supplies, is it worth getting a higher rated one if I want to crossfire in the future?
A 750w PSU is really not needed, unless you plan to OC your CPU to like ~5GHz, OC your GPU, and add a second GPU. This PSU will be more than enough if you don't plan on crossfire.
Ok thanks. Well I've never overclocked before so not sure if I'll be doing that. But I would like to add a second GPU in the near future, should I still go for more watts on the PSU or will 750w be ok for crossfire?
