Moving Components
Basic question, can I move all my components, Motherboard, GPU, PSU, from my current case  into another case?
Thanks.
yes yes yes yes yes yes yes yes yes yes yes yes yes yes ye yse yes yes yes ye ys yes yes yes ye sy eys yes yes yesy es yes yes yes yes yes yes yes ye ys yse ysesye esye yesyesyesy yes
? Not sure if srs
rofl yes you can move everything as long as the case supports the form factor of your motherboard.
Most likely. As Looming Hawk said, you need to make sure the new case supports the form factor of your motherboard. If you are using OEM parts, you may run into some difficulty as OEMs will often create their own form factors. In addition, you also need to make sure your new case has enough clearance for your CPU cooler as well as space for the mounting backplate (you should not have to worry about the backplate unless you are using an incredibly cheap case, or an OEM case.) Lastly, you need to make sure your case has enough room for your GPU, if you are using a extremely large GPU like a 7990 with a cheap case, you might find that the GPU is too long.v
Yes, the reason Id like to do this in the first place place is because my current case ( acer aspire M3985) doesnt fit my recently bought gtx 660 :( so I was either thinking a fractal design 3000 or a sharkoon t28.
I like the Sharkoon T28 with the led, it comes with 3 pre-installed fans, bu5 ive seen reviews of it being plastic and bendy material.
Some1 else recommended me a Fractal design 3000 on another post. And it looks okay, It comes with 2 140mm fans and 2 120mm fans I think, and the removable hhd bay from the middle would be easily enough to fit my GPU even if it doesnt fit with the hdd bay in.
Do any of you guys had hands on expereinces with any of these cases? Do you reckon the both good or is 1 better then the other?
