Hello everyone, as the title explains I have a second mouse which stutters and even locks up but its not a software issue, I've tried it on a fresh install of 7 and on another computer, it happens on both, so it appears to be the mouse... does anyone know why because its a fairly new mouse or if it can be fixed?
for anyone who wants to know what mouse it is, its basically this http://amzn.com/B00IFRH6JS but even more generic.
Blow gently over the sensor to remove any dust particles, and try a different surface to run it on just in case. Other than that it could simply be broken.
If its not dirt on the sensor you could use a voltmeter to check the connections on the sensor and the controller if there is a weak connection, and solder it anew if you have any experience fixing electronics (and if the pcb isn't super tiny).
Clean it, if that doesn't work use a different material of surface and make sure that surface is clean and consistent with the surface texture. If that doesn't work then it might be a defect.
