Mouse Pads
I am looking to get a new mouse pad.  I am using a CM Storm Xorent that uses an Optical sensor.  I use it at 1000 or 2000 dpi setting.  I am a medium sensitivity gamer I would say.  I play battlefield and CS GO mainly.
PureTrak Talent http://www.puretrak.com/ProductDetails.asp?ProductCode=MP-TALENT
Steel Series Qck+ http://www.amazon.com/SteelSeries-QcK-Gaming-Mouse-Black/dp/B000UYCRQ6/ref=sr_1_17?ie=UTF8&qid=1383865561&sr=8-17&keywords=gaming+mouse+pad
Logitech G240 http://www.amazon.com/Logitech-Cloth-Gaming-Mouse-Low-DPI/dp/B00DY1HTTM/ref=sr_1_54?ie=UTF8&qid=1383865872&sr=8-54&keywords=gaming+mouse+pad
XTrac http://www.newegg.com/Product/Product.aspx?Item=N82E16817114174
They all seem like good options but I want to know what you guys think and have used.
I don't use a mouse pad as I have a wood desk that is smooth.  Although I am curious about this question and if it would be worth getting one also?
Ya I dont like using mine on the desk and have just been using a cheap mouse pad that it large but is starting to get dirty and not sure if it tracks that well compared to my friends mouse on a better pad
Last mouse pad I used was a Duke Nukem 3d mouse pad...
that one is a bit small I need a larger one for the lower sensitivity I play on
