Mouse Disappears
Hey guys! Need a little help...
So when I scroll my mouse pointer to the left side, at the edge, of the screen, it doesn't get lost. As in there is a border at the left side of the screen so the mouse pointer doesn't go beyond it But on the right side, that border doesn't exist. The mouse pointer can keep going and it gets lost. Kinda hard to explain but hopefully thats good enough.
In Win 7, you can drag software like Word to either side of the screen and it'll enlarge to take up half your monitor. But because my mouse pointer disappears on the right side, i can only use this feature with the left side.
~Nikesh
Are you using multiple monitors? Because that's the only reason I can think of that the cursor would continue past the edge of the screen.
You can use hotkeys to snap windows to either side of the screen. Win key + left/right arrow keys will snap to the left or right, Win key + up maximizes, down minimizes.
Oh no I only have 1 screen. Thats why I can't understand whats happening.
