Mouse auto clicking
Recently i got a Corsair M60 mouse and after a few days some thing dodgy is happening with it...
When i hold down the left click for more than a few seconds and take my finger off the left click continues to register as if it is being constanly held down. it can be corrected just by clicking again but it is realy ennoying in-game, especialy FPS.
has anyone else had this problem too or have any suggestions on a fix? I've looked around the interwebs a bit to see if anyone else came across this but haven't found anything so far. :(
Thanks.
I would just make use of the warranty/RMA instead of attempting a fix.
Do NOT try to fix it, you will void your warranty if you do anything physical, send it back for a new one.
Ok thanks guys I'll try take it back soon :)
I got out my old logitech B110 and it has the same problem so it isn't the mouse but this is wierd
Also i think i fixed it; auto lock was on *facepalm*
