Mouse and keyboard
Ineed some advice on buying a new mouse  and  keyboard.... gaming intended. Im  on a budget so what would be the best price to performance options?
Definately try to get a mechanical keyboard if you can afford it, with mice i find the best thing to aim for is comfort, they all baffle you with numbers like polling rate and lazer sensitivity but making sure the mouse fits your hand is the most important.
My fav brand for this kinda thing is Logitech, their build quality is great and their warranty support is amazing, alot of people like razer stuff but i personally find them overpriced for what they are.
1600DPI is the sort of area you need for gaming with adjustable sensitivty, going to a store would be useful for you to handle the products to see what size and shape suits you.
