So I'm not sure if this is the right place in the forum for this question but it's cooling the cpu so I guess it is. Anyways I was wondering if you could mount the radiator on the inside with the fan on the outside of the case like this: http://i.imgur.com/8twE1Z5.jpg
I was planning on putting a corsair sp 120mm with the white ring on the outside, i think that it would look pretty slick with the white H440.
Yes you can do that but Im pretty sure you'll end up placing it back on inside (looks wise).
Thanks for the feedback, i'll see what I do when i actually get the cooler but more mounting options the better lol
