I am having troubles installing this game from the original disk. Regardless of comparability mode and directly starting the setup file in the Disk1 folder it will continue to post the same error:
"The version of this file is not compatible with the version of windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, then contact the software publisher".
Is there any way around this issue? I am running x64 windows 7.
