Motherboard Recommendation
Hello all. Unfortunately my Asus Crosshair VII Hero Wi-Fi died recently and I need a replacement. Does anyone know of an X570 motherboard that will allow for NVME raid the same way the Crosshair VII Hero did or should I just get another Crosshair VII Hero? Thanks.
Any price range you are looking at?
Ideally, < $400, but at this point I just want to know if any exist. If it or they prove to be too expensive, I’ll probably just get another Crosshair VII Hero.
Asus supports nvme raid mode,
and pretty much all the other semi highend x570 boards should basically do as well.
But in terms of speeds, it kinda depends on what kind of raid you want to do.
  • Asus Crosshair VIII Hero.
  • Gigabyte X570 Aorus Master.
Those are generally some of the better boards.
But of course you could always go and grab a new Asus Crosshair VII Hero board as well.
Isn´t that board within warrenty anymore?
I mean it´s not yet 2 years old right?
Depending on your perspective, X570 might be overkill where the future proofing doesn’t fit your needs and the potential risks are higher than you expect.
X570’s brought back mobo fans. Failure point many dislike, possible performance point under duress. I think the next models are looking at how to do away with the mobo fans so it might be worth waiting on the upgrade cost overhead. They also have mostly specs that are future proofing more than adding value to an existing X470 mobo… PCIe 3.0 has no immediate benefits to systems that don’t truly need them… no GPU’s that I know of and the only thing to maximize it I’ve seen so far are creative huge NVME NAS builds saturating the PCI lanes bandwidth. I haven’t compared the USB/etc… status, but likely minimal impact if the mobo specifically doesn’t add something you need.
Just saying it’s worth researching. I a building a B450 system as a server/workstation (non-gaming) and I’m perfectly satisfied for current/future needs fitting it even if I get a 3rd gen ryzen… I’d likely go X470 for gaming, too. X570 is on my list for a mobo I expect to last many years for future proofing, but the PCIe 3.0/other benefits from my perspective don’t look to outlast the AMD generational plan for the Ryzen’s and their mobo chipsets enough to see PCIe harfware to take advantage of it as I recall hearing the next year of Ryzens might be the last in the reverse-compatible Chipset supporting architecure gurantees from AMD which puts a big PCIe 3.0 future proof timeline concern on the board.
I’d love to stand corrected, so if anyone can please do. Your mileage may vary on all of this even if corrected; as do all chipset plans entailing multiple years of future proofing to fulfill (PCIe seems to be a longer timeline that usual on such goals, too).
Thank you everyone. According to the Asus warranty checker my board is still under warranty, so I’ll try to have them fix it first, but if that fails it’s nice to know what my options are.
