i5-4570 but Overclocked
Seagate SATA3 5 (x2)
8gb kit 1600 G.Skill Ripjaws-X
19.5" 5ms Viewsonic VA2046A
2G GTX 770 Gigabyte OC
Fractal Design Define R4 Black
Thermaltake ToughPower 80Plus Gold 750
I need a motherboard with about 2-4 usb 2.0 and 2-4 usb 3.0 more or less, if you guys have any suggestions or good experiences with your own motherboard I'd appreciate some advice/help. Thanks guys.
Also I plan on buying battlefield 4 and playing on ultra or high settings
well its a bit depending, the i5-4570 is a non K cpu, this means that it has a locked multiplier, so basicly a Z87 chipsetboard, is a bit of a waste in money, because the cpu is not fully overclockable. if you want a fully unlocked cpu then you need to look ata the I5-4670K. in this case i would recommend a Z87 board. but for a i5-4570 you would also be fine with a H87 board. i will look what i can find ☺
- i5-4570: http://pcpartpicker.com/p/2AQf0
- i5-4670K: http://pcpartpicker.com/p/129Wg
Grtz Angel ☺
