Motherboard heatsink
When i was building my new pc i accidentally hit the motherboard heatsink. It like popped, so I pressed it. Does it effect my motherboard temperatures. It was the heatsink above the cpu.
I don't understand, do you mean the heat-sink? If so you need to make sure that its properly secured in order to effectively cool your CPU, or if you mean above your CPU socket then as long as it popped again when you pressed it down it should be fine, you don't really need a heat-sink on your motherboard unless your overclocking anyway.
I understand what your talking about. It shouldn't be a problem as long as you just pushed it back into place. That heatsink is usually cooling the Vrm's and those usually have a sort of thermal tape which touches the heatsink and Vrm's. It can be moved without problems as long as it goes back to about where it originally was. The thermal tape is solid and doesn't smear like thermal paste so it can be moved without problems. For curiosity's sake what motherboard?
Here you go..
http://bit.ly/1cNl4wt   (i am assuming you whant mosfet heatsinks?)
I think he's talking about a motherboard that already has them but he just bumped into them.
Thanks man! Yes it is the heatsink that is there with thermal tape below it. The motherboard is Asus z87 A. It didnt move at all, I just felt that it popped.
I just wanted to make sure since I had crappy gigabyte board for 8350 and same happened with that board. The north bridge of that board overheated all the time while i was playing games and it sometimes throttled the fps. It turned out that it was common problem with that board. Maybe it was my 4.8 ghz overclock too that made it overheat, but I had no problems overclocking 8350 on Sabertooth.
