I havn't picked ram yet but i want 1600 or 1866 cas 9 or lower and 2x8GB dimms no more than 1.5V also :)
I want the motherboard to be able to(obviously that all the part i have aready picked work with it) use graphics integrated with my CPU, be able to overclock ram,cpu,gpu, have 4 dimm slots, be able to support 2-3 GPU's (also havn't picked those out yet ,probably 2 7970's) usb 3.0 header, and must be an ATX form factor. Thank you in advance because i'm going to buy one this weekend! Even better if you can find a deal on a mobo that is under $200 but dont put a price limit on your suggestions because who knows maybe they will probably go on sale later this weekend.
Some of your requirements are rather weird, like the integrated GPU thing, but nevertheless, if you want a high quality mobo with good OC capabilities and 8x/8x bandwidth support for crossfire the Asus Sabertooth is a good pick. I have the older LGA1156 in my rig and it's been working like a charm for ~3 years now. Adding more than two cards is not worth it btw.
Go for the ASRock z77 Extreme4 or even the extreme6 both well under 200. Check this out: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157344 I have the extreme4 and it's great along with phenomenal overclocking abilities. The board even comes with a great windows overclocking tool to let you overclock real time and store profiles. You get all the options in the world for ram overclocking, and pcie-3.0.
ya thanks it's weird you said sabertooth because that
s what i've been looking at and my requirements are probably weird because I'm just getting into PC since I want to do editing and my xbox 360 is not cutting it for games anymore, I'm just gonna play that 7 year old casually. That didn't come out right *facepalm
