Motherboard for I5 4690K 95 $
Hello, I am going to buy this processor and I'd ask which motherboard do you reccomend for it. Yes i will overclock it maybe not much but allitle.
is $95,- your top budget?
Because in that price range there arent too much decent Z97 boards to choose from.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130775
I was thinking about msi z97-g43 or MSI Z97 PC mate
Yeah Its my top budget, or I can buy another processor which is cheaper and is unlocked.
The other problem is that I live in Poland and the shipping etc. from USA / England is expensive :/
You're not going to find a cheaper unlocked cpu from intel, unless you get a pentium g3258, but that would be silly.
well basicly a Z97 board should give you unlocked overclock feutures.
So i think going with the pc mate or the G43 would be okay, if youdont go too crazy on the overclock.
