Motherboard fan headers
Hey guys.
I'm planning on a build and have a few questions.
The board is a Asus Maximus 8 Hero. In my build I will have 8 Fans.
2x intake, 3x exhaust, 1x bottom intake, and 2x Noctua cpu cooler.
According to Asus's site the board comes with:
4 x Chassis Fan connector(s) (4 -pin)
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
My question is, If i use a Y cable to connect the noctua cooler to the
Cpu fan header, can i use the OPT fan connector as a regular fan header
for the top exhaust fan?
Yes
I'd suggest you go X99 rather than getting that board, you can also just get 3 pin to Molex adapters, some 120mm fan 4 packs come with them, or the fans have molex on them in this case
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200072&cm_re=120mm_4_pack-_-35-200-072-_-Product
Also overall I wouldn't say that a noctua cooler is worth it, what build were you going to get?
