Motherboard died
My ASUS M5A97 R2.0 recently stopped working due to a DRAM_LED error on it (all other components were working fine). I bought it from amazon and they didn't have it on stock so they refunded my money back instead.
I'm looking for a new motherboard under £60 that'd go well with this build and I was wondering if you guys had any opinions on which one?
AMD FX-6300 3.5ghz 6 core processor
Avexir Core Series 8GB (2x4GB) DDR3 1600
XFX Radeon HD 7770 1GB
XFX Pro Series 450W 80+ Bronze Certified ATX Power Supply
just a second i will check partpicker for you ☺
can you afford a board that is arround 8 - 10 pounds more?
msi gaming 970
http://www.scan.co.uk/products/msi-970-gaming-amd970plussb950-socket-942-4ddr3-2pci_ex16-2pci_ex1-2pci-6sata3-4usb3
http://www.amazon.co.uk/dp/B008RPZ5H8/?tag=pcp0f-21
This are 2 very good boards.
+1
^^^^agree^^^
Which one would you prefer? It's mostly used for gaming, photoshop and editting.
I am also okay with spending about £10 more.
Well the Msi 970A gaming has nicer looks, and is a newer board with better onboard audio.
Both boards are basicly fine.
But i think that i would grab the Msi 970A gaming, because of the better onboard audio chip. and also better lan chip!
Alright, thank you very much for the help! (:
^^^^ yes ^^^^
