Motherboard Build or Other?
Hi all,
recentley I decided that I would buy the 'Asus P8Z77-V' it had what I was after in terms of USB connectivity, enough for all my peripharals and now I can't order it at a great price here in the UK.
I have seen Logan's recent 'Build Video' aswell as the one for July and the question I have is which motherboard is better, I need at least 6 USB's and 1 PCI Slot, with possible 2 card SLI.
Here are the options Logan chose; 'ASRock Z77 Extreme4' or 'Gigabyte GA-Z77X-D3H'?
Thanks ahead of time for the help.
Treeman13
well the USAP USB 3.0 is built into ALL Asus mobos so any ASUS z77 will do
