Motherboard bios updating help
I want to buy a motherboard (Gigabyte 78LMT-USB3Gigabyte 78LMT-USB3) but I have a new amd fx 6300 but in order for me to use the motherboard with this processor it is stated that I need to update the bios and I doubt the motherboard will be updated. So I was wondering if I can update my bios while my new processor is in there or I have to buy an older processor that is already compatible without updating. Thank you.
If your set on that board than buy an old processor like an athlon x2 or something. If you dont want to do that then get a different motherboard that has R2.0 or V2 after it.
But will I be able to use my fx 6300 processor to update my bios? Or am I able to access the bios without a processor. The only processor I have is the fx6300.
