Hi!
So I just installed a TX3EVO and two AF120 on the top of my case (I already had one 200mm front intake and 120mm back exhaust), and I noticed that since then, my CPU temp is 26°c to 28°c and my MB is at a CONSTANT 43°. It can't go under that value, it's like it's locked there.
Here's my temp info:
https://drive.google.com/file/d/0B_l0x3p4ftc0dmVQS0o1Q1hCeVU/edit?usp=sharing
When I restart the computer, the mb temp goes from whatever temp it was when it was off , directly to 43°C. I did not have that problem before installing the heatsink and the 2 fans. Also no OC.
Should I change something in the BIOS?
(sorry for my english btw!)
