V-My cart on Newegg-V
http://speedcap.net/sharing/screen.php?id=files/77/f3/77f396046836ceccc75fe103aec86c60.png
I need help with picking a motherboard and power supply for pc. im going to be building for gaming.
This is my first build and I am on a budget of $800
the first thing i would do is change that 660 to a 7850/7870 and at any point do you plan to use multiple GPUs, if no get a 970 board which i would say ASRock extreme 3 or 4 if yes get a 990FX board in which case i reccomend the Biostar TA990FXE
Good? http://www.newegg.com/Product/Product.aspx?Item=N82E16814127663
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102999
get either one of those instead
