Motherboard and graphics card compatibility
I recently got help with a pc build on reddit and i was just wondering if i were to upgrade my graphics card how would i know that its compatible with my motherboard and what are my choices because it was a budget build. The motherboard that was picked out for me was the MSI H81M Eco Micro ATX LGA1150 Motherboard and the graphics card is a XFX Radeon R9 280 3GB Black Edition Double Dissipation Video Card
Ummm, there really isn't a modern GPU that is "incompatible" with any modern mobo. We have no clue what the rest of your build is, so there is no way for us to help you till that info is given.
Perhaps you should do some research of your own, there is a thing called google, it works when you have internet.
CPU Intel Core i3-4160 3.6GHz Dual-Core Processor $102.99 @ SuperBiiz
Motherboard MSI H81M Eco Micro ATX LGA1150 Motherboard $57.99 @ SuperBiiz
Memory Crucial Ballistix 8GB (1 x 8GB) DDR3-1600 Memory $39.99 @ Amazon
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive $49.99 @ Best Buy
Video Card MSI Radeon R7 370 2GB Video Card $149.98 @ SuperBiiz
Case Cooler Master N200 MicroATX Mid Tower Case $40.99 @ NCIX US
Power Supply Rosewill Hive 550W 80+ Bronze Certified Semi-Modular ATX Power Supply $59.99 @ Amazon
Operating System Microsoft Windows 8.1 OEM (64-bit) $88.88 @ NCIX US
Prices include shipping, taxes, rebates, and discounts
Total $590.80
Generated by PCPartPicker 2015-08-03 04:52 EDT-0400
Should be compatible, definitely.
if i upgrade my graphics card in the near future do you think the power supply would be able to handle it just fine or should i get a better one just to prepare for that?
Depends what GPU, a 280 should be fine on that though.
The power supply is fine but your cpu is too slow to even run that 370 proficiently. Swap in these: http://pcpartpicker.com/p/2ZVgZL
can you explain to me what a 280 is. I really dont know much about computers
Type Item Price
CPU Intel Core i5-4460 3.2GHz Quad-Core Processor $176.95 @ SuperBiiz
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive $51.89 @ OutletPC
Video Card XFX Radeon R9 280 3GB Black Edition Double Dissipation Video Card $174.99 @ Newegg
Total $602.79
Generated by PCPartPicker 2015-08-03 12:57 EDT-0400
would this be fine ?
That'd be fantastic.
280 as in an r9 280. The gpu.
http://pcpartpicker.com/p/c38nVn - better mb & psu, slightly cheaper case but still good. $596
You need 500W or more, you are fine!
Gaming GPUs donĀ“t really need more than PCI-E gen3 8x from my experience.
