Most Reccomended Fans?
So i have 140MM fans all around my Rosewill Throne Case, And a Single 230MM fan that is on the side panel and blows inward to all of my hardware, What im looking for is Better fans, Something maybe Noctua or another type of fans, I'm not too knowledgeable on what to look for, But i want the best cooling possible and i don't want to worry about static pressure as well, Would anyone be able to recommend any fans for these slots and if possible, Links please?
Thank you in advance.
I wouldn't care too much for static pressure unless you had the fan pushing air through a radiator or heatsink.  I would suggest Noctuas,
Noctua certainly know how to make fans... I used one of there force series in a recent build (in a Fractal Design define r4, fan was in bottom slot, completely silent) and it exceeded expectations. The other thing is they bundle a 4 pin extension cable (can be used on 3pin fans also), 4 pin into 2x 4 pin (tacho off one only), a set of vibration reducing mountings and a voltage reduction cable. Personally I only used the extension cable and vibration mounting for that fan, but the splitter now drives the front case fans and I do have the voltage reducer if I ever need it. Worth it just for the accessories.
Having said that corsair make higher performance (and noise) fans by using higher RPM max, these cost about the same although also come in twin packs that cost less per fan (~$30 aud). These fans do outperform the Noctua equivalent except for noise, which is still decent but not as good.
Gelid solutions make a very good fan for less than ten bucks, its not a lot of air movement but its completely inaudible when running on straight 12v so if your needing a few quiet fans and not wanting to spend near a hundred bucks they a a very good option.
Finally you can get non working PSU's for free and take the fan. This works well as most PSU's use a quality fan with a good balance of airflow to pressure and noise. Perhaps not the ideal option but I use one such fan on my old system because hey, free is free and connected to a old wire wound potentiometer it works a treat for cooling the HDD's.
Thank you everyone who helped me, I think it's obvious to go with Noctua x3
