I'll start this off by talking about me and my friend's build, as relevant to our cooling/noise as I can...
As for my rig, I have the CoolerMaster 690 II Advanced with the three stock fans (two 140mm and a 120mm). A CPU cooler with a 120mm fan and a Palit JetStream 660 ti (two 80mm fans I believe).
My friend, with the CoolerMaster Storm Trooper case with about six fans, varying from 200mm to 120mm. He also has a Gigabyte 770 factory OCd with 6GB of VRAM and the Deepcool Gamer Storm Assassin cooler with it's two stock 120mm & 140mm fans. He also has an extra hard drive than me, one a WD Black and the other Green.
His PC runs A LOT quieter than mine and maintains lower temperatures, not much, but it's lower.
I have all my fans running between 30% - 40% any lower and it would make me feel uncomfortable with my cooling, the GPU is set to 30% minimum on idle, something I cannot change and don't particularly mind.
Sure, the noise isn't too bad, it's completely fine with me really. It's just I could potentially shush my rig a bit by adding/switching the fans (I would go for Noctua, of course).
Can anyone answer my shortened question; can more fans, running at lower speeds, maintain the same temps as a rig with half an many fans and be quieter at the same time?
Thanks in advance for any input.
