Hi Guys
So I have a couple questions. First is that I have broken the stand to my Dell U3011 and I am struggling to find a genuine replacement or a suitable one. The screen is just a little less that 10KG with no stand. The top of the VESA 100x100 mounting space to the base of the screen is 11 Inches, so I need some clearance to manipulate it around. Can you recommend somewhere that does sell them?
The second question is, are there any recommendations for cantilever desk mounted brackets that would support 30" screens?
Third question is, what multi monitor desk mounts (2 or 3) screens are well rated? Either stand, bracket, cantilever or fixed?
Also I am from the UK so UK stores would be appreciated.
Many thanks in advance!
