Monitors have yellow tinge to them - Help?
So I just updated my drivers for my R290x after setting up my PC in my new apt. I don't know if this was an issue before that I just never noticed (monitors were in a diff config), or if this is something new that happened after the driver update.
See photo: http://i.imgur.com/rzn6tXO.jpg
Basically my 2 Crossover Q27 LED-P 1440p monitors have some sort of weird color tint to them. It looks like they are on a "warm" setting, however this monitor has no OSD software of any kind. My AMH A399U 4k display seems to be correct, its just BOTH crossovers that I use on the sides. Maybe its possible its something I never noticed before because I just now started using the AMH panel. I'm leaning towards its a software thing though for the moment.
Any advice on adjusting the color to match would be appreciated.
