Monitors 1440 vs 21:9
Just upgraded my desktop and now I'm looking for a new monitor.
I was originally thinking going 4k but it looks like they still have a way to go before there is going to be a quality 4k monitor that is affordable. I should also say that this is primarily for editing... I want more real estate. Yes I will do some gaming on it, but thats no my first concern.
I was originally thinking of the ASUS PB278Q 27 2560X1440
its about $500
and I had been saving for one until I saw the LG 21:9 Ultrawide 25UM65 at Costco for $250.
thats half the price I was planning on spending. Now I have watched the videos on the Korean 1440 monitors and i'm not sure I want to take the risk (as small as it maybe) and I want to know I will have some support if something goes wrong.
What do you all think? Is the extra height worth double the price?
Also I need to be able to connect it easily to my macbook pro as well... i am hoping to use it as larger/second monitor.
I am open to any suggestions and any feedback especially if you have used either monitor.
As an owner of a 1440p korean for over 8months now I have to say I am very pleased with it and have had no issues with it. I personally need the extra vertical space. however I do love playing games in wide-screen. (I'm saying for a 3440x1440 panel)
From a Pixel-Price ratio the 21:9 is definatly worth it.
On both monitors you will be able to view two (maybe 3) full sized documents or windows. The only difference being at 1440p you could possibly fit 4 things (one in each corner) but then it gets crammed vertically a little bit.
If I was in your situation i would get the 1440p (so long as you do have the proper connections on your macbook [not all DVI] is equal) Then I would get the 21:9 and then a korean.
What 1440 Korean monitor did you go with?
I have a dual link DVI to thunderbolt/display port adapter but I have read mixed reviews as far as it working with macbook pros... I also have HDMI on my laptop but I dont know if that would work for 1440.
LG panel: http://www.ebay.com/itm/New-WASABIMANGO-QHD277-PRIME-27-2560x1440-AH-IPS-LED-D-DVI-Computer-Monitor-/121326529148?pt=Computer_Monitors&hash=item1c3f9fea7c
Samsung Panel: http://www.ebay.com/itm/Matte-X-STAR-DP2710LED-Samsung-PLS-Panel-WQHD-2560-x-1440-27-Monitor-/330932578190?pt=Computer_Monitors&hash=item4d0d1e678e (This one has been reviewed by teksyndacite...it's pretty damn good)
Samsung Panel: http://www.ebay.com/itm/First-FSM-270YG-LED-LG-S-IPS-16-9-WIDE-2560x1440-WQHD-27-MONITOR-/320933726714?pt=Computer_Monitors (same as the other, but with 5w speakers instead of 3w...sometimes goes down to $279)
or if you don't wan 1440p...but want the aspect ratio you can get this one http://www.ebay.com/itm/Perfect-Pixel-QNIX-QX2400-LED-Phantom-24-FULL-HD-1920X1200-D-sub-DVI-Monitor-/321052363216?pt=Computer_Monitors&hash=item4ac03649d0
this guy is actuioning a qnix...if you want to look at it...http://www.ebay.com/itm/QNIX-27-QX2710-2560x1440-QHD-PLS-Matte-Panel-Monitor/221435013484?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D20131003150253%26meid%3D6884261546470200161%26pid%3D100034%26prg%3D20131003150253%26rk%3D5%26rkt%3D8%26sd%3D221423059841
I got the X-star Dp2710 (samsung PLS panel) the one linked below except I paid the $30premium for pixel perfect. 'though I'm not sure if they still have that offer.
As soon as the 21:9 monitors were shown off at CES back in 2013, I've been a massive fan of them. Though, I have yet to own one, my friend has one.
Unfortunately his is one of the first LG models, and gaming in 21:9 has quite a bit of input lag. However, Linus has recently reviewed the new revisions of the LG 21:9 line, and they've fixed almost every issue that was previously present in the models. The input lag is acceptable on the 1440p 21:9 (quite pricey though) and the input lag is good for anything not competitive on the 29in 1080p 21:9 monitor.
I'm very interested in what Asus offers with their 1080p 21:9, and from what I've heard, the Dell is terrible for input lag
For reference, the 29in model is height-wise the same size as a 23in monitor. I don't know about your preference for size, but at about 2-2.5 feet from the monitor the 29in monitor feels the most comfortable of the 21:9 sizes imo. But if you like the idea of the 25in monitor, as I believe the one you mentioned is, then up to you. I'd prefer the 1440p in that case.
thanks everyone... I will probably pass on the LG 21:9 and go with a 1440 monitor.
Thanks again!
There are 1440p 21:9 monitors though, such as the LG whats it....
LG 34UM95 its a 34" IPS panel with 3440x1440 resolution but it's around $1,500 here in the US right now.
This screen size and resolution will probably be the next enthusiast resolution till 5K or 6K Ultra wide screen panels come out.
After seeing a LG 34UM65-P in the flesh, Im ready to off load a kidney to buy one. I could so get used to a 21:9 ratio.
"Samsung Panel: http://www.ebay.com/itm/First-FSM-270YG-LED-LG-S-IPS-16-9-WIDE-2560x1440... (same as the other, but with 5w speakers instead of 3w...sometimes goes down to $279)"
should be LG Panel: http://www.ebay.com/itm/First-FSM-270YG-LED-LG-S-IPS-16-9-WIDE-2560x1440... (same as the other, but with 5w speakers instead of 3w...sometimes goes down to $279)
