Monitor wont work!?
Hey guys, ive just got my new pc, (specs on my profile) and i tried too hook it up with vga because the HDMI is a mini and i dont have the mini cable, but when i turn the pc on, it boots and i hear the windows start up thing but the monitor says 'no signal input' this pops up for about 5 seconds then goes away, leaving the screen blank and the power indicator on yellow (standby) does anyone have any ideas on why this is?! Will i need to get the HDMI mini?
If the video card has a VGA port there's no reason why you would need the HDMI.
But if the VGA port is on the motherboard and you have a card in then it won't send the signal to the motherboard.
You know what I mean?
Are you pluging it in to the video card? I have seen people make the mastake of useing the VGA out on the mother board. And not useing the DVI to VGA adaptor that for the video card.
Im plugging it into the mobo because theres no vga on the card? :s  should thier be vga on the card?
I have it all working now guys, thanks alot!
