Well, I'm looking forward to the new year when I can finally get a desktop PC built and free myself from the laptop. The only thing is, I've not owned a desktop since the days when PC's were grey and the monitors were big cubey things. Because of this I'll need a few pointers from the community here.
I'm going to have a GTX 770 graphics card in there and I want to have more than one monitor. I two vertical either side of one horizontal monitor. But of course, I'm only going to be able to do that if the cost is right. In fact, I'm hoping to just get the larger, main monitor, sorted first, add a second later, then the third -space out the cost a little bit.
This got me wondering about how much it matters if the monitors are different. If the two side monitors are of a much lesser quality, will that be a problem? I'm thinking about refresh rate, response time etc. If I got a decent main monitor, would it be wasted by two slower, lesser monitors?
Are there specific sizes I should be looking for? Say the main monitor is 29" then what should the side monitors be if I am going to keep them vertical?
Also wondering what connectors I'm looking at. The GTX 770 has DVI and HDMI. Do I have to look for a specific type of monitor, because there's different types of DVI and all that. The 770 says it has support for up to four monitors, but I don't think there's four ports to connect to, are there?
What about monitor stands? They sure do seem quite expensive in some places. I built an ok desk, will I have to drill it much to fix these stands or anything? Do they have specific mounting connections (VESA, I think)?
So yeah, any hints, tips or advice you can share would be thoroughly appreciated.
