Monitor Setup for New House (KVM/Multi Monitor/etc)
First time poster here so go easy on me. :smiley:
I’m moving to a new house and designing my new home office. The desk I currently use won’t really work in my new office space. So I’m in the process of designing a new layout and could use some advice.
Currently I have two setups on my desk.
[u]Gaming Rig:[/u]
Gigabyte X570 Aorus Ultra
AMD Ryzen 7 3800X
32G RAM
eVGA RTX 3080 GPU
Acer Predator XB271HU Monitor
Logitech G series Mechanical Keyboard
Logitech G series Wireless Mouse
  • a bunch of other peripherals (Arctis Wireless Pro headset, etc)
[u]Work Rig:[/u]
HP Laptop w/ Thunderbolt Dock
2x Samsung S22C450 22" 1080P monitors
Logitech wireless membrane keyboard
Right now these exist as two descrete systems on my desk. This has it’s pros and cons. The biggest being I can queue up some background noise on my gaming rig while I work and not have to flip back and forth between setups. The downside is I vastly prefer my mechanical keyboard, don’t like the clutter, and am constantly twisting back and forth between the two setups.
At my new home office I want to merge this all into one setup. What originally brought me to Level 1 was Wendell’s new triple monitor KVM that allegedly supports GSync. This got me thinking as to what would be the optimum setup for me.
1.) Triple monitor setup with two 1080P panels flanking my 1440P panel powered by this 3 monitor KVM.
2.) One new Ultrawide monitor with a single monitor KVM.
3.) Leaving well enough alone and having two discrete systems.
Any thoughts? Has anyone tried GSync through and of these Display Port 1.4 KVM’s?
Thanks for the help!
  • Skip
Personally I would do a single ultra wide or 43” flatscreen. I have a triple monitor setup rn and I have lots of problems with computers and OS’s respecting the monitor layout after switching inputs, power cycles, etc.
I have used a few setups
43" + 24" Port
32",32" +15" Travel Monitor
34" Ultra + 24 on side and stacked.
And I personally like the dual 32" the most (Travel monitor optional but isnt in use when not traveling so works well as 3rd screen)
Not great for gaming imo so thats why its out same with the
as there is still issues with games that have HUDS not being good on them.
I do like having discrete monitors for when I’m on team meetings and screen sharing. That way I can share the entire screen while keeping things off screen on the other monitor if necessary.
However, looking at a monitor like the Samsung Odyssey G9 it seems like a decent cost shift by the time you factor in the Display Port 1.4 KVM and two additional monitors.
If you dont game / dont mind playing with huge black bars on the side thats a fine option. Also be aware that is a heavy monitor. If you like monitor arm mounts its hard to find a good arm for it.
Weight without Stand: 31.1 lbs
https://www.ergotron.com/en-gb/products/product-details/45-475#/tab-specs-collapse
Seems like ergo has one, I know my spaceco arms wont support it.
I do game. Which is why I wanted the GSync. I’m guessing that games other than FPS won’t really utilize that screen real estate. I was basing this off of some of the reviews I’d seen online of how good the monitor was supposed to be FOR gaming.
FPS games would be the big hit, anything where you use a HUD will be not a good exp if you ask me as that was an issue on 34" ultrawide cant imagine the issues on such a wide screen (Most games dont have adjustments for that yet)
I am a big fan of a single large display over multi displays. I use a 32" UHD as my main display, and then have a 4 port UHD @60hz KVM that lets me switch between my work laptop (on the left) and my primary gaming PC which is connected via fiber from my equipment rack.
Now I did have a 4x 24" monitor setup prior and I opted to stick it on my ceiling and attached it to a video matrix so I can swap sources in and out of the different monitors. I dont really use them as monitor extensions often and generally only when I want to “Monitor” something I have running on another computer while I am using one of my main systems.
100% the correct main size imo. My vision is too shit for those extras on the ceiling though.
I use them more like TV’s than actual computer monitors. I also have a standing desk so im not far from them.
As you can see the two on the far left and right are setup as multi-view video screens for monitoring my camera system and my video production system. The two in the center I use for random monitoring. Some times they are a screen so I can see my automated graphics server, other times they are extra outputs for testing or configuring video switcher sets.
Instead of a KVM I use a 2.7m long table, 3 computers, and I slide in my chair side to side! Much more fun…
1x27 1440/144hz + 1x504k/120hz + 1x27 1080/240hz
PC1 (multi boot, windows/linux/office/shopping/stuff) to 1440 + 4K
PC2 (multi boot, gaming, linux, entertainment/windows) to 1080 + 4K
PC3 (often server, sometimes multiboot) + 1440P/144hz
I split the 50 inch vertically then stack tasks on each half of the screen horizontally, but need to slide my (virtual KVM) chair to see it properly, if that makes any sense? It’s 5.30ammmm
Oh yeah, also, 3 sets of 100 percent “real” mice/kboards, and 6 large mouse pads, but not an issue because imo, the pc’s exist only so that mice (and periphanimals) can thrive.
This is a crazy setup and looks more like a security setup than a usable IT one.
I have a weird semetry thing where while I have a 2 monitor setup I don’t really care for it. I could make do with 2 24" monitors and one 27", but finding 16:10 monitors for a reasonable price is almost impossible.
I used to like multi monitor, but I got away from it because of bezels… They get in the middle of everything and mess with gaming as well as productivity.
With a large format wide screen or UHD I can fit 4 HD’s without bezels.
Part of why I gave up on multi monitor is because of gaming specifically. I just got so sick of trying to get games to work on multi screen, HUDs in the wrong place, games with no support or intent… It just never ended.
I used to have to disconnect monitors in some cases to game.
And yeah all the screens up top are casual, not primary. But they have the same total number of pixels as the 32" on my desk.
Right now I’m using an Acer Predator 27" 2K monitor as my gaming rigs monitor. I do a lot of system admin stuff for work and typically have multiple SecureCRT SSH sessions open as well as web interfaces at the same time. Trying to do all of that on a single 27" monitor would get pretty confusing. That’s what led me to considering a 3 monitor setup. I was also looking to save desk real estate by consolidating down. When gaming I’d probably only use the one monitor for the game itself anyway.
Have you tried to use virtual desktops?
I considered that or using something like Stardocks Multiplicty app. The problem is my work laptop is very heavily locked down for security purposes and I can’t install any non-company software. I work on the national telecomm infrastructure and some of the equipment I interact with has security ratings. So unless it’s a hardware solution it won’t work, which is a shame as a RDP or such would work just fine, I don’t need 144hz on my work machine.
Virtual desktops are built into Windows now, no need for 3rd party software.
I would try this out to start and see if it helps.
I find it very useful for day to day grouping of tasks and I find I have to do less dragging around the screen and snapping.
I would also install Fancy Zones from Microsoft as it improves the default snapping functions.
Both are first party and should work without IT getting on your case.
(Also, NEVER RDP, its the #1 security hole in MS products)
OK, I’ve come up with 3 potential solutions to my problem. They all cost within $150 of each other and very in complexity. Here’s what I have.
OPTION 1 - SINGLE MONITOR WITH KVM
Pros:
• Simplest setup.
• Full DisplayPort 1.4 end to end.
• Least amount of cables.
• Most cost effective.
• KVM’s DDC and DDM should eliminate screen resizing when changing displays.
Cons:
• Possible issues with ConnectPro KVM.
OPTION 2 - LEVEL 1 KVM W/ DISPLAYPORT REPEATERS AND SINGLE MONITOR
Pros:
• Fairly simple setup.
• Should be bulletproof.
• Potential to use HDMI output in the future for other projects.
Cons:
• Potentially the most expensive option. (surprisingly)
• More cabling needed than Option 2.
DisplayPort repeaters drop the spec from DisplayPort 1.4 to 1.2.
OPTION 3 - LEVEL 1 KVM W/ DISPLAYPORT REPEATERS AND MULTIPLE MONITORS
Pros:
• Utilizes existing equipment (Acer Predator Gsync Monitor)
• Discrete monitors make sharing a full desktop over teleconference less problematic.
• Connecting both DisplayPort and HDMI from the splitters to the monitors allows me to view both PC’s simultaneously.
• Not the most expensive option.
Cons:
• Most complicated setup with most possible points of failure.
• DisplayPort repeaters drop the spec from DisplayPort 1.4 to 1.2.
• Potentially occupies the most desk space.
Thoughts? Has anyone used the ConnectPro KVM before? I’m curious if it’s a stable piece of kit as early reviews indicated it might not be.
I wouldn’t be so sure about that :wink:
I am probably not the most reliable source but have had many customers with exotic setups return the CP and get the L1 kvm, or so they tell me.
I really don’t recommend the repeaters for an elaborate setup like this. And I think either with repeaters or the competing option you’ll be surprise by your (non) gsync experience. It passes through but “work” is another matter. Or so I’ve been told by our customers.
Repeaters are good for “problem device”
It is “bad design” of the operating system to pre-emptively re-arrange windows when the monitor is inactive. Windows 11 doesn’t do this anymore. Quadro graphics cards don’t do this. Geforce cards didn’t used to do this either but then someone was paranoid about geforce cards being used in the datacenter and this is some of the fall out.
One of our users discovered this utility for windows 10:
to save and restore window positions.
One of the reasons, as a design philosophy, the kvm doesn’t have built-in repeaters is to NOT muck up freesync/gsync. If you add l1 repeaters to the mix you will for sure not get freesync/gsync. So far the other repeaters I’ve tried that pass through the freesync bit have weird side effects, too, but what I know of CP’s kvm is from what customer have told me so idk.
Try a CP kvm before doing this craziness with separate repeaters and report back :slight_smile:
p.s. I am working on a kvm with built in repeaters For corporations / corporate customers. But I’ll never recommend that for gamers.
