Dear Logan and Wendell,
My main monitor is a 19 inch 1080p Coby tv but for what ever reason when I try to use 1080p it makes everything small... I dont know how to explain it its like everything is zoomed out to 75% so I have to use 1360x768 for everything to look okay (I still use 1080p in games). I can't figure out why this is but it is very irritating and I don't know how to fix it if you have any suggestions I will be very happy to try them. Thanks!
If your TV's native resolution is 1920x1080, there has to be a setting in your tv to change that, sometimes is called Overscan or something like that.
enable gpu scaling in the catalyst control center/nvidia control panel that will fit the Resolution to the TV
No neither of those worked.
Are you using a HDMI conection or DVI ?
it looks small because that's a fairly rediculous resolution for that small of a screen
(on desktop) rightclick>screen resolution>make text and other items larger or smaller
Ok but i cant do that because my other screen is a 4:3 one and then evrything is massive on that screen
GPU scaling is what you're looking for and that's already been mentioned. You'll need to enable it and adjust the tweaker to get it where you want.
Okay. I just found out that the native res is 1280 x 720 and I have tried GPU saling and it doesn't work
