Hello all,
Had my Ubuntu MATE system (22.04) perfected, was using Nvidia 510 drivers. Everything was tight. At random looking at nvidia-smi I noticed the power draw elevated at idle. About 75 Watts. Did some research and it was a known issue and was fixed in the 515 driver.
Updated to 515, cool power draw normalized. BUT…my monitor no longer could be set to 144hz. If I tried, it would go standby. Wouldn’t revive until reboot. Settings would not stick.
Tried via the additional drivers gui and straight from NVIDIA (heh). Figured I would need to go to most recent release for the newer drivers, gave that a try…nada.
Tried addressing settings directly in xorg.conf, tricks like set in nvidia settings and then the ubuntu display app and vice versa…nothing. Straight to standby.
Turned off and on the monitor a few times. Unplugged it, everything.
So what do I know, it works on Windows 10 at 144hz, it works on 22.04 and 22.10 with nvidia 510 drivers and nothing else. But the excess power draw…
Please offer guidance y’all, I am begging you.
before I forget the system:
Gigabyte 3080 TI Vision
Gigabyte M32U (4k 144hz)
Some LG 4k 60hz monitor
CABLES CABLES CABLES - all HDMI 2.1
Original Cable that came with monitor
Monoprice cable (successfully works for 4k 144hz driver 510)
Club 3D
Window Manager: Marco: XPresent
Ubuntu Mate 22.04 and 22.10
Proprietary NVIDIA drivers 510,515,520 and respective open kernel drivers if they exist.
Thank you all,
WWED
