I have been without a screen for about 3 months and i bought a TV to use for watching TV and with my PC. Then i remembered what TV was. So im using a 24" TV that does not suit my needs. So if anybody has any suggestions it would be appreciated. My budget is £150 ($244.61). I would like the screen to be at least 24". If i could afford a 1440p monitor that would be great but 1080p is fine. Thanks in advance for recommendation. I do some gaming, a lot of Photoshop work and Premier. I use Cinema 4D too so size matters.
http://www.ebay.com/itm/Matte-FREE-EXPRESS-X-STAR-DP2710LED-27-2560x1440-Samsung-PLS-Panel-Monitor-/330932578190?pt=Computer_Monitors&hash=item4d0d1e678e
you can get this for a little bit more.
http://www.amazon.co.uk/gp/product/B00BWOJ35G/ref=noref?ie=UTF8&psc=1&s=computers
http://www.amazon.co.uk/Samsung-S24C570HL-Monitor-250cd-1920x1080/dp/B00BFTRT18/ref=sr_1_22?ie=UTF8&qid=1391650058&sr=8-22&keywords=1080p+ips+monitor
These are under your budget and have ips panels
I think i will stretch and get the first one, thanks for the suggestions appreciated.
