Monitor Problems
My new monitor isn't displaying content on the entire display. The picture stops around an inch (more so on the sides than on the top/bottom) from the bezel. What should I do
Are you using HDMI? If so, whether you have an AMD or Nvidia GPU, open up the control utility for your card, and adjust the scaling.
mash the buttons on the side or bottom of your monitor and adjust the image size so that it streaches the the end.
otherwise just check windows to make sure you have the right resolution selected
I am using HDMI. Where is the control utility (in windows 8)?
Which type of GPU do you have, AMD, or Nvidia?
Regardless of which brand of chip you have, the control utility will be in the bottom right corner on the taskbar. (you have to go to the desktop first to see the taskbar)
