I have my primary screen an my second screen, but i want to have all my games an what not. To open on my second screen an not on my primary screen. is there anyway i can do this?
i don't want to change my primary screen to my second screen. I'm using windows 8.1 pro
You should be able to just set your second monitor as your primary, and then simply unlock and drag your taskbar over to your first monitor, which will now be your secondary. Games will launch on your second monitor, and other programs you use will generally remember which monitor you last closed them on and open there in the future. So just open them, drag them over to your secondary monitor and close them. Should work, assuming windows 8 handles things like windows 7 does.
Did try that but it doesn't do as in windows 7 which is a pain when it comes to stuff like this. all of my programs remember what screen to open, my games on de other hand doesn't. know any other workaround or way to do this?
So, wait. Your games are still opening on the same monitor? That doesn't make sense. Maybe I didn't explain it well enough. Let me try and be more clear (my previous response was a bit convoluted).
First, lets label your monitors. Your current primary monitor we'll call "Front". Your current secondary monitor we'll call "Side". What you need to do is set "Side" as your primary monitor, and "Front" as your secondary monitor. Now your takbar is on "Side". Unlock it, and drag it over to "Front", and re-lock it.
Now, your taskbar etc. is back on "Front", but "Side" is actually your primary monitor. Thus, when you launch a game, it should launch on "Side" (it shouldn't require a restart, but you may want to do one just to be sure).
If you already did all that and it didn't work, then I apologize. I just wanted to be clear. You could try setting up a profile in CCC (Nvidia control panel might be capable as well?), or maybe give ultramon a try... but I don't think it has that capability.
