Hey there was wondering if it's possible to mount monitors that don't have screw holes into monitor stands.
FYI, monitor that i'm using is the aoc I2367Fh 23"
Thanks.
Thanks.
http://www.amazon.com/Peripheral-ENCLOZE-CONVERSION-ULTR-THIN-MONITORS/dp/B00GAJIYXA/ref=sr_1_1?ie=UTF8&qid=1413407049&sr=8-1&keywords=non+vesa+monitor+mounts
Link is the solution for you, FYI those screw holes r called VESA compatibility
ahhhh thanks for the notice, plus the link
