i currently have 2 Asus ML228H monitors (1920x1800 2ms-gtg 60hz). I was wondering if they're any good. I want a 3rd monitor what would be a good match up since they discontinued them which makes them so pricey now =/
Monitors are a hard thing to recommend. Particularly when you already have 2 that are discontinued. Your best bet is to find a store with some monitors on display and decide which will be the best match visually.
Brightness, contrast and colour reproduction that is as close to what you have is what you'll be looking for. Only thing I can recommend is to stick with Asus and check out the model that replaced the model you have.
