Monitor GPU temp while using pyrit
I just got Backtrack set up with pyrit with OpenCL on my Readon 6970.  On windows I would use either MSI Afterburner or the AMD CCC, but on the MSI web site I do not see a linux build and the CCC does not show temps or fan controlls.
Can anyone recommend a linux app for checking the GPU temps
Ok I found the commands I wanted
Fan speed query:
aticonfig --pplib-cmd "get fanspeed 0"
Set fan speed (Can replace 75 with whatever % you want to set)
aticonfig --pplib-cmd "set fanspeed 0 75"
Get Temp
aticonfig --odgc
aticonfig can be replaced by amdconfig
Right now I am moving my word lists into 1 big file with this command
cat * | uniq | sort > <file_name>
